Unread 08-10-2010, 06:17 PM   #1
Default '69 Camaro RS COMP Cams Project Car
We know what some of you are thinking and no, it's not just another '69 Camaro. We wanted to show you what the guys at COMP Cams are cooking up. With a bunch of factory backing behind it, this F-Body is being prepped for service as the company's muscle car of choice for future Hot Rod Power Tours. This special project 1969 Camaro Rally Sport - as you might imagine - has quite a bit of love poured into it as well as a bunch of cool performance stuff to boot.
Images: CPG Nation
Starting with an engine built by John Lingenfelter, it's a small block 410ci Bow Tie block with SB2 heads, valve covers and intake manifold from GM Performance. Inside is a 3.750-inch stroked crankshaft spinning 6.000-inch Eagle rods and 10.5 compression slugs. All the bolts and fasteners hail from ARP as all gaskets are by Fel Pro. Included too is a Rattler harmonic balancer from TCI and rocker arms and stands by T&D Machine (1.8:1 Intake/1.7:1 Exhaust). COMP Cams provided a solid Street Roller grind shaft, roller lifters, a two-piece timing cover, valve springs, titanium retainers, valve locks and push rods. What does all this mean? How about 674.9 horsepower and 559.5 ft. lbs. of torque.
Accessories include a power steering pump, pulleys, belts and brackets by KRC Power Steering, an aluminum radiator and electric fan by Griffin Racing Radiators, a starter and alternator by Powermaster, a dry cell battery by Performance Distributors, and a water pump from Howard Stewart Components. The drive line consists of a 6-speed transmission and shifter by Richmond Gear, a flywheel, pressure plate, throw out bearing and clutch assembly by Centerforce Clutches, a drive shaft by Atlanta Drive Line, the aluminum center section with ring and pinion gear by Strange and rear end housing and axles by Currie.
There's a TON more info on this car and it's really worth your while to go to CPG Nation"] and check out the entire menu of awesome stuff that makes this Camaro a really, really cool build.
Comp Cams Shows How a Camshaft is Made NewsBot Dragzine Newsfeed 0 07-30-2010 01:05 AM
SS vs GT vs R/T - The Pony Car War Rages On NewsBot Street Legal TV Newsfeed 0 07-26-2010 04:40 PM
Comp Cams Shows How a Camshaft is Made NewsBot Street Legal TV Newsfeed 0 07-19-2010 11:54 AM
68 camaro, easy project, new built 383/4speed, lost of money invested DarkoStoj Classifieds 1 05-24-2007 07:33 AM
The New Camaro - an email from Scott Settlemire Joe The Alley 6 08-15-2006 08:53 AM
