Unread 02-10-2010, 06:40 PM   #1
daveg
daveg's Avatar
daveg I need rep points!
Default The $1000 question
Suppose you had around a grand to spend on this car. What would you do?
It ran a best of 13.40 last year with a 2.01 60'
I know the car has a 12 in it as it sits. 2 years ago I cut a 1.73 60 without the mega bites on. With the same drag radial and with the stock 86 engine.
SPECS
BLOCK: stock
DISPLACEMENT: 302
ROTATING ASSEMBLY: stock
CYLINDER HEADS: stock with egr bumps removed
CAM: E303
INTAKE: explorer
THOROTLE BODY: modified 65mm explorer
MASS AIR: stock
FUEL SYSTEM: stock
EXHAUST: 1 5/8 coated shorties, offroad X, welded thrush 2 chambers, stainless tails
TRANSMISSION: 1990 world class T5 with pro 5.0 shifter and alum quadrant
REAREND: stock with 3.73 richmond gears
ELECTRONICS
ENGINE MANAGEMENT: stock A9L processor (mass air swapped)
IGNITION: stock with blaster coil
GAUGES: stock
SUSPENSION AND CHASSIS
FRONT:
K-MEMBER: stock
STRUTS: stock
SPRINGS: stock
BRAKES: stock
WHEELS: 15x3 weld drag lites
TIRES: 165 radials
REAR:
SHOCKS: stock
SPRINGS: stock
CONTROL ARMS: HPM mega bite
BRAKES: stock
WHEELS: 15x8 drag lites
TIRES: Bald BFG drag radials
CHASSIS STIFFENING: none
daveg is offline   Reply With Quote
Unread 02-10-2010, 07:06 PM   #2
What are your goals for the car Street.race,etc? You could thow a bottle on it. But taking some weight outta the car will help. It all depends on what your plans are for it.
Unread 02-10-2010, 07:14 PM   #3
daveg
daveg's Avatar
I am making a street car that will survive the strip and go as fast as I can afford. Other than that everything is game. It doesnt have a/c, and the power steering is next. The batt is in the trunk etc.
I was thinking suspension, a real tire and spray.
Unread 02-10-2010, 07:23 PM   #4
red347lx
red347lx's Avatar
red347lx I need rep points!
Buy a 347 shortblock from Craigslist!
red347lx is offline   Reply With Quote
Unread 02-10-2010, 07:32 PM   #5
daveg
daveg's Avatar
when I do another motor it will be windsor based.
Unread 02-10-2010, 09:36 PM   #6
badass86
badass86's Avatar
badass86 I need rep points!
when i removed my powersteering out of mine fan ect, i didnt notice nothing besides it was a pain in the ass to steer! but yea i would spray the hell out of it!
badass86 is offline   Reply With Quote
Unread 02-10-2010, 09:58 PM   #7
make it light, kmember, coil overs, struts, rear suspension etc. that way that 1000 is not wasted and you wont ever have to upgrade those parts and it will make it faster because it will work better.
STREET DRIVEN DAILY, STREET RACED NIGHTLY
DETROIT STREET RACING DVD'S FOR SALE, PM ME IF INTERESTED
Unread 02-11-2010, 05:50 AM   #8
daveg
daveg's Avatar
Thats what I was thinking. I can drop a few hunderd on it every once in awhile this summer and make it faster. Next year I bite the bullet and throw a motor at it. I know that 60 sucked, and a light car with a working suspension can handle pretty much anything I put in it. I already have a coilover kit for the front thanks to Jamie.
Unread 02-11-2010, 07:05 AM   #9
565bbccarbed
565bbccarbed's Avatar
565bbccarbed I need rep points!
Default possibilities
Remember to put the reinforced boxes in the body where the new solid control arms get installed with the poly bushings too (upper adjustable ) .I personally seen 2 of these floors ripped from stock abuse ,by the backseat inner seat belts ripps and tears the floor. Also don't forget the 90/10 front struts installed with your coil over kit and tubular k member . Last easy thing spool or mini spool with the gear 4.10 or 4.30 ,although I had good luck with a ford racing carbin fiber posi clutch kit .Good luck possibilities endless watch this video of a frankenstang (383 stroker small block chevy 350 turbo 4.10 posi 8.8 axle 26 hoosier et's ) on my racespace . http://www.racingjunk.com/profile/236526
565bbccarbed is offline   Reply With Quote
Unread 02-12-2010, 08:35 PM   #10
daveg
daveg's Avatar
I have a real good friend helping with my chassis now. I havent bought the parts yet, but we have a plan.
Thanks everyone who had input.
Unread 02-17-2010, 11:53 PM   #11
NineD5OH
NineD5OH's Avatar
NineD5OH I need rep points!
I would say if your not planning on putting another motor in it go with a nicer set of heads. Hell you can even reuse the heads on the windsor if you decide to go that route. I'd try and pick up a set of used AFR 185's. might be a little big for the 302 but when you step up to the windsor it will be just right. I'd say you could probably pick up 50-60 horse easy with them heads....
NineD5OH is offline   Reply With Quote
Unread 02-20-2010, 05:45 PM   #12
PizzaBoy
will 9.50s be fast enough
PizzaBoy's Avatar
PizzaBoy I need rep points!
Front K-member,front coil overs,a-arms to make it light and some spray
I'm bustin Cutlass Steve's ass this summer
PizzaBoy is offline   Reply With Quote
Unread 02-20-2010, 09:17 PM   #13
daveg
daveg's Avatar
Yeah, thats almost exactly what we are thinking, but instead of some spray we were thinking a bunch...lol
I was under the back a couple days ago and noticed the housing bushings were pulled out of the housing and just hanging on the upper control arms. I guess you could say it has a better 60 in it...
Unread 03-26-2010, 06:20 PM   #14
daveg
daveg's Avatar
I just bought heads, intake and cam. Gonna see how much this stock bottom end can handle
Unread 03-26-2010, 07:08 PM   #15
PizzaBoy
PizzaBoy's Avatar
Are you fuel injected or carb? Either way the bottom end will hold up pretty good. Ur pistons should be forged so u can throw some spray at it too
2001 Sallen Question ProJect83 The Shop 2 06-25-2008 09:30 AM
I have a question Xx96GTxX The Alley 16 04-07-2006 03:27 PM
Being asked the question? Steve Starnes The Alley 19 11-14-2005 09:59 AM
Question on calculating RPM at given speed x gear 99SVTAddict The Alley 9 09-26-2005 04:15 PM
Trans Question cobrafreak01 The Shop 5 09-07-2005 03:45 PM
