This started out as a '67 Stepside driver we bought in 1991. Here is what it looked like when we first bought it:
This is what it looked like right before the big hit in April 2004. Like the 68-69 Camaro/Nova hubcaps
Chassis is a 1972 1/2 ton 5 lug, front disc, dual exhaust, GM Big Block mounts, front sway bar setup. Powdercoated gloss black from front to rear.
- Rear fuel tank is from FuelCellGuy - www.aluminumfuelcellcom
- Moog pitman and idler arms with local rebuilt power steering gear
- PST Front end rebuild kit (rubber) - www.p-s-t.com
- PST Trailing arm bushings (Poly)
- Early Classic 4/6 drop kit - www.EarlyClassic.com
- Rear end is a GM 12 Bolt, DTS 3.73, Posi, Moser axles - www.drivetrainspecialists.com
- Stainless Steel Brake lines & hoses - www.InlineTube.com
- Front fenders, rad support, grille, bed panels are all original GM metal I have located locally. Only the tailgate is reproduction.
Cab is currently awaiting some rust repair on the frame mounts, floors and corners along with some minor mods. We just started working on the powertrain this month
