Unread 08-31-2011, 12:50 PM   #1
jacobs93
jacobs93 I need rep points!
Default Turbo ???
Hey everyone im new to detroit racing and want to say hi and i have a question i have a 93 notch and i want to put a turboed 351 in it and that about as far as i have gotten my goal is to run 8.00 to 8.50 ? i have been buying a few parts here and there like i have a QA1 K member and A arms and a few engine parts but how do i know which turbo to use or do i buy one and build the engine to withstand it or build the engine and add the turbo that works best with it? HELP ??? thanks for any input
jacobs93 is offline   Reply With Quote
Unread 08-31-2011, 03:05 PM   #2
Do you need to go 8.0 or 8.50? There's a big difference in power at that level. I went in that range with a mild 347 and a GT-4788 turbo @ 3200#.
Unread 09-01-2011, 05:51 AM   #3
jacobs93
??? i guess not but thats my goal i know if i go 8.50 or slower i car legally run with just a 12pt cage vs. 25.2 i think and i know the other safty stuff isnt a strict either so it might be cheaper and easier to obtain??? i should also say that i already have a 92 351w out of a f250 so that y i want to it since i already have it would you build the car first like chassis and suspension or the engine and build the car around that ?
Unread 09-01-2011, 07:23 AM   #4
Even 8.50's aren't a joke, you will need both the power and the chassis to run that number. If you're going to use a stock windsor block, I wouldn't try to go faster than mid 8s, even that is pushing it on a production block.
If you picked up a gt4788 and built a forged 357 with the stock block and a set of out of the box Victor Jr or TFS heads, you could run that number.
Unread 09-01-2011, 11:18 AM   #5
jacobs93
thanks for all the help you have given me alot to think about and what i really want to do with the car
Unread 09-01-2011, 11:50 AM   #6
jacobs93
what about turbonetic's turbos? are they any good?
Unread 09-03-2011, 11:42 AM   #7
Turbonetics has some good stuff too, but they are normally kinda of expensive because they have ball bearings, which aren't necessary at all for what you're doing. I think the gt47-88 is a great unit for what you want because it will run quicker than 8.50 and won't need a lot of motor to do it. It also spools really fast.
Turbo Mustang Helps People Turn Tragedy into Triumph NewsBot Dragzine Newsfeed 0 07-25-2011 02:16 PM
FastLane's First Turbo Kit For '11 Mustang GT 5.0L NewsBot Street Legal TV Newsfeed 0 07-19-2010 06:30 PM
Trade my Banshee for Turbo and E.F.I stuff Underpressure55 Classifieds 2 03-10-2010 10:37 PM
Stock GN Turbo Low miles! 0 shaft play! NICE PHOTOS! thunderace31 Classifieds 2 04-21-2006 11:07 AM
2.3L Turbo Parts!! 357windsor Classifieds 0 07-15-2005 07:35 AM
