Unread 07-10-2011, 10:16 PM   #1
Boomer!
Infraction Jackson !!!!!!
Boomer!'s Avatar
Boomer! I need rep points!
Wrench Ford 408 stroker long block (best offer)
SVO351 (4 bolt mains on 2,3,5 journals) (list $937.50 that is not including machining)
Eagle pn# 14124 rotating assembly 4030 crank, H beams (list $2,417.24)
ARP rod bolts
Probe piston flat top ( static compression 12.75:1) low tension rings
Canfield 215cc runners 54cc chambers, 2.08", 1.60" valves (no rockers or push rods)
ARP head bolts
Canton Racing Products 15-670 ($239.95 )
Balanced rotating assembly
New timing chain set ( double roller adjustable key way)
2 cam shafts available (1 nitrous cam {custom ground} 1 N/a cam) specs will be given to buyer.
Serpentine belt system included with single wire 60 amp alt
Moroso electric water pump
March Pulley kit with alt bracket ($575)
Miscellaneous machine work HV oil pump, ect. ($1344)
New timing cover
Single plane intake tapped for direct port nitrous
This engine has about 15 passes on it since rebuilding in 2009 and ran low 10's in a 2800lb Mustang.
I have a 950 cfm Holley carb, MSD distributor, MSD cap an wires, vacuum pump with mandrel and -AN hoses and fittings set up for the engine all at additional cost. I also have a huge 3 core aluminum radiator with fans set up and ready to drop in.
This engine will last and I can freshen it up before purchase if you choose, at a additional cost. I will also have the ports cleaned up on the heads if the buyer chooses.
I have receipts for most of the parts on this engine and know it in and out as I have had it apart a few times over the years for general service and inspection.
I am moving on to a larger combination and would prefer to start from scratch
Any questions please feel free to ask. I am sure i am missing a butt load of parts on this combo.
Asking $6000 but $5200 cash in hand will get it loaded into your transportation upon arrival
I am pretty firm on the price however i will work out a deal if somebody buys the entire combo.
I really don't need to sell this as i planned to put in another car further down the road, this will fund getting my other car moving forward.
Please PM any questions, I rarely have much time to check up on the forum lately. Pictures available through text, please serious inquiries only
Thanks,
Boomer
Boomer! is offline   Reply With Quote
Unread 07-18-2011, 03:50 PM   #2
kennyb68
kennyb68 I need rep points!
Default engine
Interested in selling the short block only?
Ken
kennyb68 is offline   Reply With Quote
Unread 08-10-2011, 10:37 PM   #3
Boomer!
Boomer!'s Avatar
yep, $3500 and it is yours.....
Summit Racing Now Offers Summit Ford 347 Engine Blocks NewsBot Street Legal TV Newsfeed 0 07-09-2010 11:43 AM
Ford Now Offering Over 9,000 Reproduction Car Parts NewsBot Street Legal TV Newsfeed 0 06-09-2010 05:32 PM
R302 or stock 351W block for stroker? Fiveohcrazy The Alley 16 05-05-2009 09:34 AM
Ford Employee Appreciation Day @ NMRA Milan, MI Promedia Lisa Events 0 04-30-2008 08:39 AM
Small Block Ford FMS (Crane) Retrofit Hyd Roller Lifters Fryguy302 Classifieds 0 09-25-2007 09:04 PM
