Misc. Parts for sale dirt CHEAP or FREE
Strange 33 spline axles spool for 8.8 with big bearing 9" ends. Axles are for narrowed rear in a mini-tubbed FOX. One axle shaft is twisted kinda hard, and should be replaced. $120 for all.
Black Magic type electric fan, $40 (The shroud seal measures 16x17 almost square)
Spal 16" 10 blade fan, $60
Foxbody Koni Struts - Adjustable orange konis, need rebuilt, $50
Stock LS1/LS2 Rocker arms - $50
MSD coil for 7 series ignition. Not the HVCII coil the weaker one than that. $40
Cast FMS valve covers for 351 Cleveland heads or Yates style heads. Painted black. AN fitting welded on one head seeps oil, $20
1987 Grand National Header Panel, has cracks, kinda rough - Free
Ancient Global West caster plates for FOX body - Free
Black Magic fan, shroud measures 16x17 $40
Spal 16" 10 blade straight fan $60
Sirocco style griffin aluminum racing radiator, kinda dinged up but no leaks and works fine but needs a fitting welded on, $40
Parts must be picked up in Holly.
